Forum >BlunoBasicDemo as android serial flow forwarder
"By the way, you should notice that other Apps for BLE talk might NOT compatible. If you need to develope your own App, you can customize the BlunoBasicDemo which is open source. Link."
In which extend BlunoBasicDemo can manage the connection with Bluno and not other Android BLE applications on the shelf ? what is the technical key point that makes the difference ?
To make in use standard Android applications with Bluno, how to simply modify BlunoBasicDemo code to forward the serial bluetooth flow to other android applications on the mobile that are to get a serial flow -bluetooth, usb...- in input ?
Regards.
Regards.
