Forum >Android bluetooth
Bluno General Arduino
Android bluetooth
userHead Account cancelled 2017-08-27 20:13:10 4045 Views2 Replies
So I have been successful at interfacing with my beetle ble with my bluno. My next step is to replace the bluno with my Android phone.
Basically all I have been doing with the bluno is updating my code on the computer, such as changing a look up table, and then uploading it to the ble over bluetooth. I would like to do the same thing but just using my phone. Is there a way to do so?
Pete
2017-12-02 07:31:06 why can the phone not interface with the device via the bluetooth? and how do we connect to it with an app? I have to say, your documentation for your products is horrible. the worst i have seen in a long time. which is really unfortunate because you make such wonderful hardware. if everything is going to be documented as bad as this ble beetle then im going to have to stop using your products simply because i wont be able to figure how to use them. userHeadPic kirkvarra
2017-09-05 01:45:04 For phones, you need an app to communicate with BLE device, you can't use the phone's build-in Bluetooth. so if you want you phone has those functions, you need to have your own app which will uploading the data to BLE device. userHeadPic robert.chen
