Forum >Firebeetle Battery
Easy IoT General
Firebeetle Battery
userHead Account cancelled 2017-09-02 04:45:48 4460 Views1 Replies
Do lipo batteries I use need to have a protection circuit on them or is this already in the charging circuit on the firebeetle.
Could I for instance use a 18650?
2017-09-27 01:47:58 In the circuit of Firebeetle, it has the design of the protection that make sure the battery will not charge the current back to the usb port, so basically the usb port will charge the battery and the battery will power firebeetle , you can have a look of this post viewtopic.php?f=8&t=3073#p12328 userHeadPic robert.chen
