Forum >The x axis switch is stuck on overlord 3d printer pro
3D PrintingGeneral
userHead dvella212 2017-09-05 20:55:42 3824 Views1 Replies
Shold i swap out for a new switch. I checked the cables and everything look good. Could it be the switch itself??
2017-09-29 18:06:28 Turn off the printer. Check the conductivity of x axis switch when triggered and when not triggered. If the switch keeps showing open circuit when triggered, the switch must be broken, you need to change a new one userHeadPic robert.chen
