Forum >What is the stall current of the Micro Metal motor- 6V
RoboticsTroubleshooting
userHead martin.sivertsen 2017-10-03 01:03:15 3735 Views3 Replies
Hello, I am designing a PCB and would like to find out what the stall current of the motor mentioned in the title is.
I am using two of these motors and would like to lay down a PCB-trace that handles the stall current from both with room to spare.
Link to the motor in question: https://www.dfrobot.com/product-1432.html
2023-03-17 13:38:02
Hi, I am designing also a PCB, but for the following motor
- Micro Metal Geared motor w/Encoder - 6V 530RPM 30:1  (ITEM FIT0481)
(https://www.dfrobot.com/product-1431.html)
does someone know if this also apply ?
Regards,
Enrique
userHeadPic Enrique.Vidal
Enrique.Vidal wrote:
I went also ahead and I uploaded a video were I made the test, here the link
https://youtube.com/shorts/vTGAobnKgKA
current with no load: 54mA
stall current: ~540 mA.
2023-04-09 06:39:35
2017-10-03 03:27:39 I went ahead and measured it myself.
The current with no load was 54 mA and the stall current was ~480 mA.
So there you have it, in case anyone else should wonder in the future.
userHeadPic martin.sivertsen
