Forum >DFR0107 Infrared Receiver Kit
userHead Account cancelled 2017-10-15 20:21:56 1907 Views1 Replies
Having trouble making this kit work. I uploaded the code on the wiki but all it gives me is "Error" whenever I press something on the provided remote. I changed output_verify and output_key to 1 and the serial monitor prints "Remote 7 verification code" when i press 7, it either hangs, gets an error or says key 0 not programmed. Could someone pls help me? I need a step by step process on how to get this to work
2017-10-20 03:11:40 I test it and it works OK, you don't need to change the output pin, did you plug the IR receiver to pin 2? userHeadPic robert.chen
