Forum >How to achieve micro usb to UART connection?
TroubleshootingGravity
userHead DerrickChao 2022-04-15 10:46:20 1927 Views16 Replies
Sorry for the newbie question, I am trying to achieve the UART connection as pictured below: https://wiki.dfrobot.com/Gravity:%20I2C%20&%20UART%20NFC%20Module%20SKU:%20DFR0231-H
What is the simplest way to achieve this connection?
Do I need a converter like this and then use a micro USB to micro USB cable? https://wiki.dfrobot.com/FTDI_Basic_Breakout_3.3_5V__SKU__DFR0065_
Or would I get the Adafruit USB A to TTL cable and then a USB A to micro USB converter?
Thank you!
2025-01-26 20:22:36
The IPL has always been a platform for exciting cricketing action, memorable moments, and unmatched fanfare, and the upcoming season is expected to carry forward this legacy. With new strategies, player line-ups, and rivalries, the 2025 IPL season is bound to be a spectacle that no cricket fan will want to miss.https://aajkaiplmatch.net/
userHeadPic Daniel.McCormick
2025-01-05 13:07:59
When a woman from modern-day Korea falls asleep with some sleeping pills, she later awakens in the infant body of Athanasia. Knowing the unenviable fate that https://whomademeaprincess.net/
2025-01-02 15:00:55
Spotify Premium Apk esasen resmi Spotify Android uygulamasının modded bir sürümü. Kullanıcıların Spotify'ın tüm premium özelliklerini herhangi bir maliyet https://spotifyapk.info.tr/spotify-lite-apk/
2024-12-05 17:07:54
I had a similar challenge and ended up buying a 5V output TTL converter, which worked perfectly for me. It's awesome retro games
userHeadPic thunder.333
2024-12-03 22:52:52
I assume you're aiming to connect your PC to NFC. Any USB to TTL converter should work for this, but make sure to check the voltage levels.
https://kimetsu-noyaiba.online/
Isabella
userHeadPic Oli.via
2024-11-04 14:33:30
I faced a similar challenge, and I ended up purchasing a 5V output TTL converter, which worked perfectly for me. You might want to give it a try too!https://yandexapk.info/
userHeadPic Emily R..Askew
2024-11-04 13:58:47
USB to UART converters, or bridges, function as serial ports on your computer, allowing for serial data transmission over a few wires. They enable a serial connection to other devices. In this article, we'll explore how this technology works.https://whomademeaprincess.net/
userHeadPic Shakira C..Baron
2024-10-26 14:57:28
Friesian Horse Breeds https://animalatoz.com/friesian-horse/
userHeadPic alex.jon
2024-10-26 12:52:33
To achieve a micro USB to UART connection, use a micro USB to UART adapter or cable, connecting the TX, RX, and GND pins appropriately. Install any necessary drivers and configure your terminal software for communication.https://godesertsafari.com/blog/
userHeadPic Shirley.Brenner
2024-10-06 04:12:03
To achieve a micro USB to UART connection, use a micro USB to serial converter or cable that provides UART pins. Connect the TX, RX, and GND pins from the converter to the corresponding UART device pins.https://worldtriggermanga.online/
userHeadPic Heather.Thurber
2024-09-21 20:55:45
To achieve a micro USB to UART connection, use a USB-to-UART adapter that has a micro USB connector. Connect the adapter's TX, RX, and GND pins to your device's corresponding UART pins.
userHeadPic Grace.Deshong
2022-04-16 18:31:15
I had a similar challenge and I just purchased a 5v output TTL converter and the work was done perfectly. You can try your luck too.
all the best
userHeadPic simonmugo
2022-04-16 11:55:22
i try it but did not work
userHeadPic williamjon
2022-04-16 07:05:33
Thank you both.
userHeadPic DerrickChao
2022-04-16 01:00:23
USB to UART converters or bridges present themselves as a serial port to your computer and send serial data over a couple of wires. They can be used to make a serial connection to another device. In this post we’ll look into how this works.
userHeadPic FabianWilson
2022-04-15 18:35:26
I assume that you intend to make PC talk to NFC.   Any usb→ TTL converter will do the job.  Just be aware of the voltage level.
userHeadPic R2D2C3PO
