Forum > Infrared CO2 Sensor SKU: SEN0219 PWM - Analog mode
TroubleshootingGravity
userHead CarlosMenoni 2022-04-17 18:47:55 1095 Views1 Replies
I bought this sensor https://www.dfrobot.com/product-1549.html . It says it is analog, but it also says it is PWM (i didnt see this before).
There is any change that i could do, to make it work in analog mode? Or could i get the analog signal from any place in the board? I understad that i could damage the sensor.
I notice that the sensor could work in uart mode, analog mode or PWM mode.
Please let me know if this is possible.
2022-04-19 05:25:40
I think the description is not correct. From the wiki, the sensor only supports PWM output.
userHeadPic R2D2C3PO
