Forum > PM2.5 Sensor Adapter V2.0 (SEN0233)
Troubleshooting
userHead ahmedgueye 2022-04-21 05:02:06 861 Views3 Replies
My name is Ahmed Gueye, I am a student researcher at the Cheikh Anta University in Dakar.
I bought a PM2.5 Sensor Adapter V2.0 (SEN0233) DFROBOT. I have tried the two codes you have published but I can't get any data.
I need your help to complete my research please.
2022-04-29 02:58:18
Hello, I plugged it into the 3.3V pin but it still doesn't work. I used the schema and code that you proposed. Here is the diagram
userHeadPic ahmedgueye
2022-04-22 01:11:14
Also, make sure your microcontroller is 3.3V as the sensor works under 3.3v.
userHeadPic R2D2C3PO
2022-04-21 18:44:21
please post your wiring diagram,  did you use Arduino or raspberry Pi
