Forum >Firebeetle - Arduino board manager index URL wrong
userHead EdwardWaudby 2022-04-24 09:24:54 836 Views2 Replies
In your articlr on setting up the M0 Firebeetle device, here, it specifies one should add this link (http://download.dfrobot.top/firebeetle/package_firebeetle_index.json)  into the additional boards manager URL list.
However, the actual link appears to be http://download.dfrobot.top/firebeetle/package_DFRobot_test_index.json
Maybe it's being tested or something but “package_DFRobot_test_index.json” should be renamed to “package_firebeetle_index.json” or the article should be updated.
Reporting it here in case someone else has a problem
2022-04-26 01:43:41
Linke has been fixed. Thanks for pointing out.
userHeadPic R2D2C3PO
2022-04-24 19:05:08
Thanks.
