Forum >Fermion DFPlayer PRO speed
userHead Alejandro TulioCamus Hernandez 2022-04-25 10:30:44 1186 Views1 Replies
Hi! I am thinking of doing a project where I'd be detecting vibration with a piezo sensor and playing samples when detecting vibration.
Project requirements/wishes.
- Use Rpi pico- Store around 60 samples of 1s in length- Be fast/responsive
I am considering:
- Storing the samples as .wav or .mp3 on the pico storage and then play them with a PWM pin.- Gravity or Fermion DFPlayer (Memory included in module)- Fermion DFPlayer (with sd card)- Using an SD module + DAC
I guess the Fermion DFPlayer PRO would beat the sd card approaches on terms of speed. I suppose storing it in the pico itself would be even faster (?) but then there are memory constraints (2mb).
Ideally I would use the Fermion DFPlayer because of its storage capacity. In your experience would that be fast/responsive enough to not show significant delay when for example activating it with a piezo sensor by playing a drum really fast? Is there any data on audio latency for the Fermion DFPlayer PRO module?
Thanks!
2022-04-26 05:50:30
Not sure about it.  It will be always good to know a new appliaction.
userHeadPic R2D2C3PO
