Forum >Is DO Sensor and pH sensor works on saltwater?
General Arduino
userHead MLT 2022-04-27 03:53:54 1596 Views3 Replies
Hello! I am currently pursuing my thesis. My topic involves monitoring system in saltwater farms. With this, I want to ask if the available DFRobot Gravity: Analog pH sensor and DFRobot Gravity: Analog Dissolved Oxygen sensor is applicable in saltwater? If yes, are there any effects on my measured values when using the sensors in saltwater? thank you guys!
2022-04-28 04:34:33
You can do some experiments with saltwater such as ploting.
userHeadPic R2D2C3PO
2022-04-27 21:53:09 Thank you for answering, are there any ways to calibrate it to saltwater? userHeadPic MLT
2022-04-27 16:49:18
These sensors are not calibrated in saltwater, and the parameters of the algorithm are not sutiable for such scenario.  The sensor readings are meaningless.
