Forum >Failed to install board Firebeetle ESP8266
userHead Francois06 2022-04-28 17:24:34 1845 Views3 Replies
I'm trying to install on the boards manager of Arduino IDE the board FireBeetle-ESP8266 using the link :
http://download.dfrobot.top/FireBeetle/package_firebeetle8266_index.json
or
https://raw.githubusercontent.com/DFRobot/FireBeetle-ESP8266/master/package_firebeetle8266_index.json
But none of them are working, it failed with the following error :
Failed to install platform: firebeetle8266:firebeetle8266.
Error: 9 FAILED_PRECONDITION: Platform 'firebeetle8266:firebeetle8266@2.3.3' not found: getting tool dependencies for platform firebeetle8266:firebeetle8266@2.3.3: tool mkspiffs not found
Do you know how to fix it ?
Thank you
2022-05-05 17:41:13
Link has been fixed.  Try this  http://download.dfrobot.top/boards/package_DFRobot_index.json
userHeadPic R2D2C3PO
2022-04-29 12:35:47
At least do you have any tutorial to install it manually ?
Thank you
userHeadPic Francois06
2022-04-28 19:00:33
AAA
userHeadPic Youyou
