Forum >pressure water sensor SEN0257 output current
I use pressure sensor SEN0257 to measure water level in caves.
Can you tell me the max current of the output ?
2022-05-16 13:32:14
REMYDenis
Thanks,
I know that it's a voltage signal, but i would know what is the internal amplifier output impedance.
thanks
2022-05-09 18:34:18
Youyou
This sensor output the linear voltage signal, not the current singal. The output voltage range is 0V to 4.5V.
