Forum >Which Radar Doppler sensor for measuring distance?
How to select
userHead TjerkJongsma 2022-05-11 00:10:18 663 Views0 Replies
Hi there,
I am looking for a Radar/Doppler sensor to measure the feed content of a container without having to make a hole in it. So I want to know the distance measured from above. The tank itself is made of polyester. Which sensor do you recommend?
The module and radar sensor is powered by a battery.
Thank you for your help!
