Forum >Some problems on SEN0158 IR CAMERA
So I recently purchased this module and mounted it on Arduino. I used the sample codes that have been provided on wiki.
The problem is that it doesn't seem to perform as the sample mentioned.
1) It cannot detect laser dot on surface. The sensor could only detect the direct IR source.
2) The detection range/angle is extremely small. I could only detect laser dot that was directly shot to the surface of camera.
I've also tried the processing codes and the outcomes are the same. The camera only detect IR signal within a small area at centre. Something like this:
Did I do something wrong on using this product? Can anyone help me with this issue? Thank you.
