Forum >Husky SD File System Info
HUSKYLENSSuggestions
userHead anonymous 2022-05-15 05:34:36 2228 Views1 Replies
All files written to the SD Card get the same data/time info, making it impossible to determine any chronological sequence.
Is it possible to adjust the starting clock settings of the Husky processor, even if it is manually, and achieve a better time stamp info ?
Or maybe some sequence number type of info can be attached to files, allowing one to determine any kind of precedence.
2022-05-16 02:39:40
Good idea. Maybe we could modify some fake create time info to easily get the sequence of the saved model.
Thank you!
userHeadPic Angelo.Qiao
