Forum >Dfr0760 Speech Synthesis code help
Troubleshooting
userHead jessiekitzmiller 2022-05-18 22:19:58 829 Views1 Replies
Hello all. It would see the company has since switched to a version 2 of the speech synthesis chip. I had a friend write this code for me for the original version 1 of the chip. Since the new version my code does not work. Could someone please help?
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_ICM20X.h>
#include <Adafruit_ICM20948.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_GFX.h>      // Needed by SSD1306 library
#include <Adafruit_SSD1306.h>
#include "DFRobot_SpeechSynthesis.h"
// Pin assignments and defines
// reserved pin for Serial1 (used by DFRobt Gravity TTS)
const int ser1TXPin = 18;
const int ser1RXPin = 19;
// reserved pins for I2C (used by sensor and display)
// The pins for I2C are defined by the Wire-library.
// On an arduino MEGA 2560: 20(SDA), 21(SCL)
const int i2cSDAPin = 20;
const int i2cSCLPin = 21;
// General defines
//#define MY_DEBUG_VERSION
#define SERIAL_MONITOR_BAUD_RATE 115200
#define DFROBOT_SERIAL_BAUD_RATE 115200
#define DELAY_BETWEEN_WORDS_MS 90000UL
#define SPEECH_VOLUME 10 // you can modify the volume here, range [0..10]
// ICM-20948 defines
// nothing here
// SSD1306 defines
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// reset pin for OLED display, it is -1 because the I2C module doesn't have a reset pin
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
#define SCREEN_ADDRESS 0x3C
#define TEXT_SIZE 2
// Variables
#include "words.h"
Adafruit_ICM20948 icm;
Adafruit_Sensor *icm_temp, *icm_mag;
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
DFRobot_SpeechSynthesis_UART tts;
float lastMag = 0;
float lastTemp = 0;
char wordBuffer[max(maxWordLen, 80) + 1];
// Words management
bool getWord(const int index)
 if ((index < 0) || (index >= numWords))
   Serial.print(F("Internal error: word index "));
   Serial.print(index);
   Serial.println(F(" out of bounds"));
   return false;
 strcpy_P(wordBuffer, (char *)pgm_read_word(&(words[index])));
 return true;
// display the word centered on the screen
void displayWord()
 int16_t x0, y0, w, h;
 display.clearDisplay();
 display.getTextBounds(wordBuffer,0,0,&x0,&y0,&w,&h);
 if (w < SCREEN_WIDTH)
   x0 = (((int16_t)SCREEN_WIDTH) - w) / 2;
 else
   x0 = 0;
 if (h < SCREEN_HEIGHT)
   y0 = (((int16_t)SCREEN_HEIGHT) - h) / 2;
 else
   y0 = 0;
 display.setCursor(x0, y0);
 display.print(wordBuffer);
 display.display();
void speakWord()
 tts.speak((const void *)wordBuffer);
void processWord(const int index)
 if (!getWord(index))
   // index out of bounds, do nothing
   return;
 Serial.println(wordBuffer);
 // display the word on OLED
 displayWord();
 // speak the word on the speaker
 speakWord();
void pickAndDisplayNextWord()
 // read the current magnetometer and temperature sensor values
 sensors_event_t mag;
 sensors_event_t temp;
 icm_temp->getEvent(&temp);
 icm_mag->getEvent(&mag);
#ifdef MY_DEBUG_VERSION
 Serial.print("Temperature ");
 Serial.print(temp.temperature);
 Serial.println(" deg C");
 Serial.print("Mag X: ");
 Serial.print(mag.magnetic.x);
 Serial.print(" \tY: ");
 Serial.print(mag.magnetic.y);
 Serial.print(" \tZ: ");
 Serial.print(mag.magnetic.z);
 Serial.println(" uT");
#endif
 float newMag = sqrt(sq(mag.magnetic.x) + sq(mag.magnetic.y) + sq(mag.magnetic.z)); // magnetic field absolute value, in uT
 float newTemp = temp.temperature; // value in degrees Celsius
 // If this is our first reading...
 if (lastMag == 0)
   // Store our readings as a baseline and return
   lastMag = newMag;
   lastTemp = newTemp;
   return;
 // Calculate the absolute variation in magnetic field/temperature
 float deltaMag = abs(newMag - lastMag);
 float deltaTemp = abs(newTemp - lastTemp);
 // Get the biggest change of the two
 float index = max(deltaMag, deltaTemp);
 // Convert to an index of our dictionary array
 long wordIndex = round( index * 1050.0 );
 while( wordIndex >= numWords )
   wordIndex -= numWords;
 // Store the readings for the next loop
 lastMag = newMag;
 lastTemp = newTemp;
 // speak and display the word
 processWord((int)wordIndex);
// Arduino setup() and loop()
 Serial.begin(SERIAL_MONITOR_BAUD_RATE);
 wordBuffer[0] = '\0';
 // Display setup
 // SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
 if(!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS))
   Serial.println(F("SSD1306 allocation failed, program halted"));
   while(true)
     delay(10); // Don't proceed, loop forever
 // Clear the buffer
 // Show the display buffer on the screen. You MUST call display() after
 // drawing commands to make them visible on screen!
 // display.display() is NOT necessary after every single drawing command,
 // unless that's what you want...rather, you can batch up a bunch of
 // drawing operations and then update the screen all at once by calling
 // display.display().
 display.display();
 display.setTextSize(TEXT_SIZE);             // Normal 1:1 pixel scale
 display.setTextColor(WHITE);        // Draw white text
 // ICM-20948 setup
 // Try to initialize!
 if (!icm.begin_I2C())
   // if (!icm.begin_SPI(ICM_CS)) {
   // if (!icm.begin_SPI(ICM_CS, ICM_SCK, ICM_MISO, ICM_MOSI)) {
   Serial.println(F("Failed to find ICM20948 chip, program halted"));
   while (true)
     delay(10);
 Serial.println("ICM20948 Found!");
 // accelerometer and gyro unused, but set the range anyway
 icm.setAccelRange(ICM20948_ACCEL_RANGE_16_G);
 icm.setGyroRange(ICM20948_GYRO_RANGE_2000_DPS);
 // the magnetometer has fixed range 4900 uT, set the number of lectures per second
 icm.setMagDataRate(AK09916_MAG_DATARATE_10_HZ);
 icm_temp = icm.getTemperatureSensor();
 icm_temp->printSensorDetails();
 icm_mag = icm.getMagnetometerSensor();
 icm_mag->printSensorDetails();
 // Text to speech setup
 Serial1.begin(DFROBOT_SERIAL_BAUD_RATE);
 //Init speech synthesis module
 tts.begin(Serial1);
 tts.setLanguage(tts.ENGLISHL);
 tts.setVolume(SPEECH_VOLUME);
 // Default initialization, done in tts.begin
 //Set voice volume to 10
 //tts.setVolume(10);
 //Set playback speed to 4
 //tts.setSpeed(4);
 //Set speaker to female
 //tts.setSoundType(tts.FEMALE1);
 //Set tone to 5
 //tts.setTone(5);
 //For English, speak word
 //tts.setEnglishPron(tts.WORD);
 // print some statistics
 Serial.print("Num words: ");
 Serial.println(numWords);
 Serial.print("Max word length: ");
 Serial.println(maxWordLen);
 pickAndDisplayNextWord();
 delay(DELAY_BETWEEN_WORDS_MS);
2022-05-19 14:20:58
anyone?
userHeadPic jessiekitzmiller
