Forum >i have a problem with sd
LattePandaGeneral
userHead gesterthell 2022-05-20 06:38:51 1455 Views1 Replies
Hello, my name is Gester. i have a problem with sd I tried a 32GB sd card with lattepanda but the window doesn't recognize the card. With a 2 GB card it works fine. What is the SD card size limit on this board? . Suggestions and ideas are greatly appreciated. Thank you in advanceHello, my name is Gester. i have a problem with sd
What is the SD card size limit on this board? . Suggestions and ideas are greatly appreciated. Thank you in advance\
เว็บคาสิโนออนไลน์
2022-05-21 07:20:49
What is the model or SKU of your LattePanda board? In addition, could you provide detailed information or the model of your SD card?
userHeadPic Youyou
