Forum >Gravity: MEMS Gas Sensor (MiCS-4514)
GravityTroubleshooting
userHead AhmedElashouti 2022-05-22 07:50:57 1468 Views1 Replies
I am trying to get the MEMS sensor ( which is working via i2c) running with esp32. I am trying to write a C code running on esp-idf .Unfortunately only examples for arduino code is provided other than that I can't find any documentation on how to communicate with the sensor ( on which frequency does the sensor operate ? ). I can't establish a successful communication with the sensors via i2c and i am not sure where the problem is. I waited for 3 mins warm up and then tried to wake up the sensors and finally reading values. however I don't receive any acknowledgement from the sensor. I tried the four different addresses ( 0x75 till 0x78) provided in the datasheet. I would appreciate if someone take a look in the code.
#define I2C_MASTER_SCL_IO 22                   /*!< gpio number for i2c slave clock */
#define I2C_MASTER_SDA_IO 21                   /*!< gpio number for i2c slave Data */
#define I2C_MASTER_FREQ_HZ    100000           /*!< I2C master clock frequency */
#define I2C_MASTER_TX_BUF_DISABLE 0            /*!< I2C master doesn't need buffer */
#define I2C_MASTER_RX_BUF_DISABLE 0            /*!< I2C master doesn't need buffer */
#define WRITE_BIT I2C_MASTER_WRITE              /*!< I2C master write */
#define READ_BIT I2C_MASTER_READ                /*!< I2C master read */
#define MEMS_SENSOR_ADDR  0x75              /*!< slave address for BH1750 sensor */
#define ACK_CHECK_EN 0x1                        /*!< I2C master will check ack from slave*/
#define ACK_CHECK_DIS 0x0                       /*!< I2C master will not check ack from slave */
#define ACK_VAL 0x0                             /*!< I2C ack value */
#define NACK_VAL 0x1                            /*!< I2C nack value */
#define           OX_REGISTER_HIGH          0x04
#define           OX_REGISTER_LOW           0x05
#define           RED_REGISTER_HIGH         0x06
#define           RED_REGISTER_LOW          0x07
#define           POWER_REGISTER_HIGH       0x08
#define           POWER_REGISTER_LOW        0x09
#define           POWER_MODE_REGISTER       0x0a
#define           SLEEP_MODE                0x00
#define           WAKE_UP_MODE              0x01
#define           OX_MODE                   0x00
#define           RED_MODE                  0x01
#define           CO                        0x01          // Carbon Monoxide
#define           CH4                       0x02          // Methane
#define           C2H5OH                    0x03          // Ethanol
#define           C3H8                      0x04          // Propane
#define           C4H10                     0x05          // Iso Butane
#define           H2                        0x06          // Hydrogen
#define           H2S                       0x07          // Hydrothion
#define           NH3                       0x08          // Ammonia
#define           NO                        0x09          // Nitric Oxide
#define           NO2                       0x0A          // Nitrogen Dioxide
static esp_err_t i2c_master_init(void)
    int i2c_master_port = 0;
    i2c_config_t conf = {
        .mode = I2C_MODE_MASTER,
        .sda_io_num = I2C_MASTER_SDA_IO,
        .sda_pullup_en = GPIO_PULLUP_ENABLE,
        .scl_io_num = I2C_MASTER_SCL_IO,
        .scl_pullup_en = GPIO_PULLUP_ENABLE,
        .master.clk_speed = I2C_MASTER_FREQ_HZ, // 100 KHZ
        // .clk_flags = 0,          /*!< Optional, you can use I2C_SCLK_SRC_FLAG_* flags to choose i2c source clock here. */
    esp_err_t err = i2c_param_config(i2c_master_port, &conf);
    if (err != ESP_OK) {
        return err;
    return i2c_driver_install(i2c_master_port, conf.mode, I2C_MASTER_RX_BUF_DISABLE, I2C_MASTER_TX_BUF_DISABLE, 0);
static esp_err_t i2c_read_sensor_data(i2c_port_t i2c_num, uint8_t* data)
    int ret=0;
    i2c_cmd_handle_t cmd = i2c_cmd_link_create();
    ESP_ERROR_CHECK(i2c_master_start(cmd));
    ret=i2c_master_write_byte(cmd, MEMS_SENSOR_ADDR << 1 | WRITE_BIT, ACK_CHECK_EN);
    ret=i2c_master_write_byte(cmd, OX_REGISTER_HIGH, ACK_CHECK_EN);
    vTaskDelay(10 / portTICK_PERIOD_MS);
    ret=i2c_master_write_byte(cmd, MEMS_SENSOR_ADDR << 1 | READ_BIT, ACK_CHECK_EN);
    i2c_master_read(cmd, data, 6, ACK_VAL);
    ESP_ERROR_CHECK(i2c_master_stop(cmd));
    ret=i2c_master_cmd_begin(i2c_num, cmd, 1000 / portTICK_PERIOD_MS);
    printf ("err  cmd begin read = %d \n", ret);
    ret=0;
    i2c_cmd_link_delete(cmd);
    return ret;
static esp_err_t sensor_wakeup(i2c_port_t i2c_num)
    int ret=0;
    ret=i2c_master_write_byte(cmd, 0x0a, ACK_CHECK_EN);
    ret=i2c_master_write_byte(cmd, 0x01, ACK_CHECK_EN);
    ret = i2c_master_cmd_begin(i2c_num, cmd, 1000 / portTICK_PERIOD_MS);
    printf ("err  cmd begin write = %d \n", ret);
    ret=0;
    return ret;
void task(void *pvParameters)
  uint8_t recv_data[6]={0};
  int ret=0;;
  while (1)
  ret=i2c_read_sensor_data(0, recv_data);
  for (int i =0; i < 6; ++i)
      printf ("data[%d]= %d \t",i, recv_data[i] );
    printf ("\n");
    recv_data[i]=0;
  vTaskDelay(1000 / portTICK_PERIOD_MS);
void app_main(void)
    ESP_ERROR_CHECK(i2c_master_init());
    vTaskDelay(100 / portTICK_PERIOD_MS);
    sensor_wakeup(0);
    xTaskCreate(task, "MEMS_Task", 2048, NULL, 4, &task_handle);
