Forum >Which installation W10 zip for DFR0444 S70CR200-CC34F ?
userHead VincentHURET 2022-05-23 08:07:22 1827 Views7 Replies
Hello
I have installed “LattePanda v1.1 4G x64 image.zip”, recommended W10 OS for this DFR0444 per the website. Installation is ok but after, I get an error saying that windows is not installed.,
So, do somebody have some idea ? Is this LattePanda v1.1 4G x64 image.zip the right one ?
Thanks for your help.
Have a nice day
Vincent
2022-05-25 09:15:50 userHeadPic VincentHURET
2022-05-25 09:15:33
2022-05-24 17:13:58
Hi Vincent
Please show us the error message.  Thanks
userHeadPic R2D2C3PO
2022-05-23 22:32:35
Hi Vincent,
First pls check if you download the right image for your LattePanda.
Download link:(x64 version for all CR200 z8350 (2GB+32GB and 4GB+64GB)) https://www.dropbox.com/s/85rtj34atn0p99v/LattePanda%20v1.1%204G%20x64%20image.zip?dl=0
second, pls share us the error screenshot that you got after installation. We will help check it.
thanks.
userHeadPic Queenie.Le
VincentHURET wrote:
Hi Queenie.Li
Thanks for your help. It is out of the box product and I plan to use several hundreds of those if ok, so I appreciate. Yes, I have carefully follown the procedure and install the recommended OS as you decribed.
Installation was ok..at one moment at the end, it ask me to exit and, what I did.
The error messages are as attached. Thanks a lot. Vincent
2022-05-24 06:17:35
2022-05-23 08:15:49
VincentHURET wrote:
Hi Queenie.Li
2022-05-24 06:14:37
