Forum >FireBeetle ESP32-E & 0.96" 80x160 display
userHead IanBrown 2022-05-30 06:20:41 1150 Views1 Replies
I'm using the FireBeetle ESP32-E and 0.96" 80x160 display. When I plug them into my own code, in VSCode with Platform.IO, the code works, uploads and displays nothing.
So I went back to basics and loaded each of the examples from the DFRobot_GDL library (st7735 80x160) into the Arduino IDE 1.8.13 IDE and all worked first time - so the wiring is right, the code works and the ‘ballCollision’ sample works great. I then moved the example into VSCode PlatformIO, … nothing is shown. The backlight is on, but there's nothing on the display. I'm doing some debug output to Serial.println, so I can see that the board hasn't crashed.
The only change I had to make to the library was in DFRobot_Picdecoder_SD.cpp to put a #if 0 at the top and #endif at the bottom as it failed to find SD.h:
    .pio/libdeps/firebeetle32/DFRobot_GDL/src/DFRobot_Picdecoder_SD.cpp:4:10: fatal error: SD.h: No such file or directory
Now, there is an SD class in
    /Users/ianbrown/Library/Arduino15/packages/DFRobot/hardware/esp32/0.2.1/libraries/SD
And
    /Users/ianbrown/Library/Arduino15/packages/esp32/hardware/esp32/1.0.6/libraries/SD
My platformio.ini contains:
[env:firebeetle32]
platform = espressif32
board = firebeetle32
framework = arduino
monitor_speed = 115200
lib_deps =
fastled/FastLED@^3.5.0
robtillaart/float16@^0.1.6
h2zero/NimBLE-Arduino@^1.3.8
hideakitai/MPU9250@^0.4.8
asukiaaa/MPU9250_asukiaaa@^1.5.11
dfrobot/DFRobot_GDL@^1.0.1
But that must be for the espidf framework - whereas the DFRobot_GDL library is claimed to be compatible with the Arduino framework. If I set the framework to espidf then VSCode PlatformIO can no longer see the DFRobot_GDL library at all.
Given the code works in Arduino IDE 1.8.13, I presume the framework should be set to ‘arduino’ in platformio.ini in VSCode PlatformIO. I also get the same problems in Arduino IDE 2.0 as I do in VSCode PlatformIO - but then IDE 2.0 is based on VSCode.
So, what can I test next to see what's causing the difference in behaviour?
I'd much rather stay with VSCode PlatformIO as it's a much more professional IDE.
2022-05-30 21:27:05
Sorted it.
The examples show the following:
#define TFT_DC D2
#define TFT_CS D6
#define TFT_RST D3
Changing that to the following just works:
#define TFT_DC 25
#define TFT_CS 14
#define TFT_RST 26
userHeadPic IanBrown
