Forum >Maqueen Plus and Bluetooth extension together :(
TroubleshootingArduino
userHead MariuszNiziołek 2022-06-05 01:12:48 522 Views3 Replies
Hello DFRobot :)
When a project includes Maqeen Plus there is no possibility to add Bluetooth extension due to incompatibility.
Could you provide Maqueen Plus extension supporting Bluetooth? It looks that IR and Bluetooth can't be used together. So I think it would be enough to provide Maqueen Plus extension without IR support (simply exclude IR support from existing Maqueen Plus extension for users who want to use Bluetooth).
Due to the problem above there is no possibility to control Maqueen Plus via smartfon Bluetooth  :( :( :( !!!!!
My micro:bit version is V2.21 with the latest firmware (v. 0257).
Can you help me? Or maybe somebody solved the problem?
Best regards
Mariusz
2022-09-19 23:30:22 Android App facilitates pairing and flashing programs to the micro:bithttps://support.microbit.org/en/support/solutions/articles/19000051025-pairing-and-flashing-code-via-bluetooth
Bluetooth implementation on the micro:bit:
https://tech.microbit.org/bluetooth/
userHeadPic jenna
2022-06-21 08:36:24
Not. I simply want to control remotely Maqueen Plus V2 via bluetooth using android tablet.
Unfortunatelly makecode bluetooth library is not combatible with Maqueen Plus V2
Do you know any solution ?
Best regards
Mariusz
userHeadPic MariuszNiziołek
