Forum >Solar Module causing frequent resets of Raspberry Pi 3B+
userHead jasta 2022-06-15 09:41:49 1072 Views2 Replies
Hi all, I purchased the Solar Power Manager 5V 1.1 module (DFR0559) hoping to use it for a solar powered robot project however I'm finding that it's causing frequent but unpredictable/inconsistent resets of my Raspberry Pi 3B+.  Sometimes the system fails to boot while my voltmeter shows a very low voltage coming out of the power module of ~3V (and also a strange humming sound from the RPi), other times shortly after booting if I run some command like dmesg a couple of times the system just “hard” resets and my ssh session freezes. Nothing seems obviously wrong like a super high current surge or voltage fluctuations outside of tolerance (voltmeter shows values in the ranges of 5.04-5.1V @ 400-800mA).  I can confirm that with my simple off-the-shelf USB power banks the RPi can be powered on indefinitely and without these problems at all.  My test set-up is as follows:
Battery (3400mAh, 3.7V): https://www.amazon.com/dp/B08H1NZLY7?psc=1&ref=ppx_yo2ov_dt_b_product_details
Solar Panel (6W, 5V): https://www.amazon.com/dp/B09JFYPDNC?psc=1&ref=ppx_yo2ov_dt_b_product_details
External power from 5V @ 1A USB from my PC
I've tried a variety of configurations to debug the issue and can confirm that the random reboots / startup issues occur even with only the battery connected (no solar panel, no USB power from the PC).  I was unable to confirm whether they agree while solar powered due to poor weather in my area right now.
I know that the RPi can draw more than the 900mA current the module is rated for, however I did extensive testing before purchase to confirm my project does not have current demands that high, even at its peak of ~800mA.  I understand this still could theoretically be a problem if there is a spike that I can't detect/catch, though I'm unsure how to even go about diagnosing that.
Is there anything more I can do to try to diagnose what might be going on?  Thanks in advance!
2022-06-16 13:57:50
Further troubleshooting I discovered the low voltage output (~3V via USB out) is caused by the battery being nearly empty or physically removed, even when 5V USB in is provided.  This surprised me a little bit, but is workable.  I started wondering if perhaps the resets are caused by insufficient current from the battery and the power module not pulling from the USB input (or solar in a real world deployment), but unfortunately I'm stuck as I'm not sure how I can even test that without buying a bunch of batteries and testing them all.
userHeadPic jasta
2022-06-15 11:53:45
I should also clarify that I did install the cooling fin.  The unit does certainly generate heat though it never is too hot to touch/handle and best I can tell the resets are not due to overheating, especially because the RPi always automatically reboots.
userHeadPic jasta
