Forum >I2C Gravity Multiplexer - Arduino
ArduinoTroubleshooting
userHead NishanthSugumaran 2022-06-22 10:21:25 1270 Views1 Replies
I am fairly new to Arduino world. I am trying to use multiple I2C Sensors on a Gravity I2C multiplexer. I see that the address has been set to 0x70. When i run the basic frame structure given by the company i never recognizes the multiplex.
#include <DFRobot_I2C_Multiplexer.h>
#include <Wire.h>
//*Create an I2C Multiplexer object, the default address of I2C Multiplexer is 0X70*/
void setup(void){
 DFRobot_I2CMultiplexer I2CMulti (0x70);
I2CMulti.selectPort(0); //Select Port 0
... //Initialize the I2C Device on Port 0
I2CMulti.selectPort(1); //Select Port 1
... //Initialize the I2C Device on Port 1
I2CMulti.selectPort(8); //Select Port 8
... //Initialize the I2C Device on Port 8
void loop(void)
... //Communicate with the I2C Device on Port 0
... //Communicate with the I2C Device on Port 1
... //Communicate with the I2C Device on Port 8
The highlighted code gives me error stating  exit status 1
'DFRobot_I2CMultiplexer' does not name a type; did you mean 'DFRobot_I2C_Multiplexer'?
2023-01-17 22:56:37
Hi!
Sorry, we updated the library, please check.
DFRobot_I2C_Multiplexer/examples/multiSsd1306 at main · DFRobot/DFRobot_I2C_Multiplexer · GitHub
userHeadPic jenna
