Forum >FIT0441 connector
Troubleshooting
FIT0441 connector
userHead Seahawk 2022-06-28 22:14:34 950 Views3 Replies
I've been trying to identify the plugs on the end of the supplied lead so that I can source longer cables. I've not been able to match them with anything, so I think I must have the data wrong.
What manufacturer and family is the connector on the motor?
2022-09-16 11:56:51
The connectors are Pico blade connectors (as well as the pins). These are made by Molex. Molex can also make the cables with varying lengths.
So, the Molex part number is 15134050X  note: "X" is length specific. 0 = 1.96", 1 = 3.9", 2 = 5.9", 3 = 11.8", 5 = 17.4" and 6 = 23". So for example, Molex part number 151340500 is a 1.96" long cable.
You will also find the mating connectors on the Molex site. Molex part number 530470560 is a through hole connector and 532614005 is a surface mount connector.
userHeadPic Glenn Varnon
2022-09-10 10:53:25
Who is the manufacturer?
2022-07-06 17:47:28
The interface specification of FIT0441 is PH1.0 5pins
userHeadPic Winster
