Forum >SEN0343 problem
TroubleshootingArduino
SEN0343 problem
userHead tuubeli 2022-07-06 09:18:57 1332 Views3 Replies
Hi!
I bought an arduino UNO board somewhile ago and decided to experiment with SEN0343 sensor. I had problems with compiling the sample code from wiki.DFRobot when the auto-calibration function “lwlp.autoCorDrift();” brought error: 'class DFRobot_LWLP' has no member named ‘autoCorDrift’ .
Then I checked the API Function list and it seems that the auto calibration differential pressure drift is stated as: “void autoCorDrift();”
Changing that line of code in the sample I got it running but only readings I get from the com are:
"Differential Pressure: 595.24 pa
Temperature: 85.00 C ".
And those numbers wont change. Is it most likely an connection issue or was that change in the code a mistake?
edit: I connected the sensorboard with the 2.54-4P Black Single Row Pin Header that came with the sensor to the breadboard and from there with wires to the UNO. Shouldn't be any problems here?
2022-07-07 05:35:30
No, I used the header pin that came along the sensor.
userHeadPic tuubeli
2022-07-06 17:42:22
Hi, Are the sensor's 4PIN pins soldered? Can you share your wiring if it's convenient
userHeadPic Winster
