Forum >SIM7000 Shield only works when plugged in to PC
userHead ATTester 2022-07-20 23:56:08 2054 Views2 Replies
We are trying to communicate with the SIM7000E shield module from a CubeCell HTCC-AB01 board via SoftwareSerial.
SIM7000E shield is connected to 12V.
CubeCell is connected to PC via USB.
CubeCell & SIM7000E shield grounds are connected.
CubeCell Rx is connected to SIM7000 Rx through a voltage divider due to the difference of logic level voltages between them.
The CubeCell is constantly sending the AT command “AT” and waiting for a response. The command seems to be sent without any problems, but no response is ever received.
However, if I connect the SIM7000E shield's USB to the PC the CubeCell start receiving the AT commands responses. When I disconnect the cable the CubeCell stops receiving again.
This is very odd behaviour. Any help on shedding some light on the issue is very much welcomed.
Thank you.
2023-02-04 05:55:08
Also check the voltage and current ratings of your power supply. You can check the voltage with a multimeter to be sure.
