Forum >Object Classify - Strange ID numbers
General HUSKYLENS
userHead tguneysu 2022-07-25 06:54:23 943 Views4 Replies
I did a factory reset for a fresh start and then I was training the HL for handwritten numbers 0-9. I prepared about 4 or 5 images for each number and then started the training process by holding down the right button, while scanning all the images of each number.
It stopped learning after number 7 and the frame numbers would not increment and ID assignments would not show anything but 0.
Then when I wanted to see whether anything could be recognized by the camera, I started seeing ID numbers that were huge positive and negative:
It looks like, it experienced some kind of failure where the ID number assignments started overflowing the assigned number range.
When I query the camera for the number of learned blocks, it keeps displaying 1000.
As it is now, I am not able to train more than 7 numbers out of 10.
Can you tell me if this is a bug ? And if so, how an I remedy the problem.
2022-07-25 07:21:14
I have a copy of the learned Object CLassify data.
If needed, I can send it.
userHeadPic tguneysu
2022-07-25 07:13:52
A bad ID#:
2022-07-25 07:13:07
a bad ID#:
2022-07-25 07:12:14
The pictures did not show up, so I am providing the ID numbers displayed on the screen while recognizing:
-1893584640
-749318853
1726535771
