Forum >Change components TDS Sensor to change measurement range
Hey, is it possible to change components on the Gravity Analog TDS Sensor to archieve a wider measurement range?
2023-03-03 17:51:47
Bob.Zhuang
I think the measurement range can be increased by changethe component parameters. Why do you need a wide measurement range?
2023-03-02 23:19:28
NeloKin
HI
If you are asking Gravity: Analog TDS Sensor/ Meter for Arduino(SKU:SEN0244), I'm afraid you can't.
It is an analogue sensor, which generates 0 voltage at 0ppm and 2.3 v at 1000ppm, which means that the measurement range is fixed by hardware.
Hope it can help.
