URM07 UART ERROR
Hello there,
Hope you all are doing good! I received the URM07 Ultrasonic sensor. I interfaced with the Arduino with the UART protocol with the help of URM UART library provided by the DFRobots. I continuously getting the value 0 in serial monitor. As mentioned in the datasheet. The LED in the back blink once and indicated the system is ready. But the communication is not happening and LED stays off.
What seems to be the Issue? Look forward to hear from you people
2017-10-24 15:19:51 Did you follow the steps in the wiki? and what's the Arduino you used? robert.chen
