Forum >Lattepanda Triple 4k display?
General LattePanda
userHead shringkel 2022-08-02 04:29:45 2386 Views2 Replies
I'm attempting to figure out if it's possible to have a triple 4k display setup on a lattepanda. I don't mind using newer equipment but I want to have a pocketable desktop rig for moving about, but when at home I want 4k displays for movies and such. Is this even possible?
I know USB C can take two(?) displays but don't know if it can handle two 4k, I know there are USB displays out there too. I'm Maybe sitting in a pipe dream about having a super smol desktop rig that can do this sort of thing.
No gaming, just movies and youtube, netflix, the usual stuff.
2022-09-10 02:10:23
Following this post
userHeadPic alexachris
2022-09-09 10:37:51
Just couple related points: the CPU limits this, of course.Delta3 - i N5105 celeron:https://www.intel.com/content/www/us/en/products/sku/212328/intel-celeron-processor-n5105-4m-cache-up-to-2-90-ghz/specifications.html?wapkw=n5105the CPU does support 3 displays, indeed, and both HDMI and DP do support 4K.There is eDP, HDMI and another DP on USB-C available on the Delta3.Also, the main product page https://www.lattepanda.com/lattepanda-3-delta shows exactly this: small touch via eDP connector, then HDMI and finally USBC connected large panel with HDR support.Imho, rather problematic may be connecting the display to the eDP feature connector - no idea, if it supports 4K and if there is a way to convert from this special connector to a normal DP cable.
userHeadPic StepanKment
