Forum >Loading Learned Objects Models
userHead tguneysu 2022-08-03 13:03:33 1391 Views1 Replies
I have successfully saved and loaded models before.
As of today, the models saved earlier do not get loaded!
I get a response that says OK in the function return, but on the camera screen there is an error message that says “File Not Found, OK”.
When I examine the SD card in the PC, all the files are there and I can open and read them.
What can be the cause of this?
I am in urgent need to access my previously saved models!
2022-08-09 22:27:08
Hi, It may be because the model of the imported algorithm is different from the current recognition mode of the sensor or the file is corrupt. Please try to learn the new model and load it immediately after importing the SD card to see if it can be read.
userHeadPic Winster
