Forum >Integrating A02YYUW and RaspberryPI
General Raspberry Pi
userHead PeterK 2022-08-08 23:32:13 1751 Views1 Replies
Setup
-   Have an running RaspberryPI 4 with either a DSI or SSH for access available
-   Have a A02YYUW sensor
Configuring RaspberryPI
The sensor needs to be attached to the UART bus. If you don’t know what UART is, this is a good link with a primer on how the UART works.
https://www.electronicwings.com/raspberry-pi/raspberry-pi-uart-communication-using-python-and-c
By default, the primary UART is assigned to the Linux console. If you wish to use the primary UART for other purposes, you must reconfigure Raspberry Pi OS.
cd /boot
Add the following two lines to config.txt
enable_uart=1
dtoverlay=disable-bt
Reboot the RaspberryPI.
Check if the UART is setup correctly.
ls -l /dev | more
You should see two lines passing by
lrwxrwxrwx  1 root root           7 aug  7 22:17 serial0 -> ttyAMA0
lrwxrwxrwx  1 root root           5 aug  7 22:17 serial1 -> ttyS0
This means that the output of serial0 is forwarded to ttyAMA0.
Connecting RaspberryPI and A02YYUW sensor
The sensor has 4 wires: power, ground, transmission and receive
I’ve used the following setup:
-   Sensor red wire = power => RasberryPI pin 4
-   Sensor blue wire = TX => RaspberryPI pin 8 = GPIO14 = UART_TXD0
-   Sensor green wire = RX => RaspberryPI pin 10 = GPIO15 = UART_RXD0
-   Sensor black wire = ground = Raspberry pin 14
Download the A02YYUW sensor library from
https://github.com/DFRobot/DFRobot_RaspberryPi_A02YYUW
/home/pi
sudo git clone https://github.com/DFRobot/DFRobot_RaspberryPi_A02YYUW
You should see a new directory
pi@raspberrypi:~ $ ls -l
totaal 40
drwxr-xr-x 2 pi   pi   4096 mrt  4  2021 Bookshelf
drwxr-xr-x 2 pi   pi   4096 mrt  5  2021 Desktop
drwxr-xr-x 6 root root 4096 aug  7 22:44 DFRobot_RaspberryPi_A02YYUW
drwxr-xr-x 2 pi   pi   4096 mrt  5  2021 Documents
drwxr-xr-x 2 pi   pi   4096 mrt  5  2021 Downloads
drwxr-xr-x 2 pi   pi   4096 mrt  5  2021 Music
drwxr-xr-x 2 pi   pi   4096 mrt  5  2021 Pictures
drwxr-xr-x 2 pi   pi   4096 mrt  5  2021 Public
drwxr-xr-x 2 pi   pi   4096 mrt  5  2021 Templates
drwxr-xr-x 2 pi   pi   4096 mrt  5  2021 Videos
cd into the DFRobot directory
The directory consist of:
pi@raspberrypi:~/DFRobot_RaspberryPi_A02YYUW $ ls -l
totaal 36
-rw-r--r-- 1 pi   pi   1287 aug  7 22:04 demo.py
-rw-r--r-- 1 root root 2465 aug  7 21:08 DFRobot_RaspberryPi_A02YYUW.py
drwxr-xr-x 2 root root 4096 aug  7 21:08 examples
-rw-r--r-- 1 root root  285 aug  7 21:08 library.properties
-rw-r--r-- 1 root root 1053 aug  7 21:08 LICENSE
-rw-r--r-- 1 root root 2269 aug  7 21:08 README_CN.md
-rw-r--r-- 1 root root 2227 aug  7 21:08 readme.md
drwxr-xr-x 3 root root 4096 aug  7 21:08 resources
To check if the setup works
cd examples
python3 demo_get_distance.py
If you have connected the wires correctly you should see the following output:
pi@raspberrypi:~/DFRobot_RaspberryPi_A02YYUW/examples $ python3 demo_get_distance.py
Distance 1641 mm
Distance 1645 mm
Distance 1645 mm
Distance 1641 mm
Distance 1645 mm
Distance 1653 mm
Note: that if you move the sensor, the distance doesn’t change. I don't know why that is.
However, if you restart the script, the values are correct. So for static (non-moving) measurements like a waterlevel in a tank this is ok.
2022-11-12 02:12:58
Is there a way i can use 2 A02YYUW with 1 raspberry pi?
userHeadPic Fedez
