Forum >MiCS6814 sensor not woking with pi
userHead TarekKhalil1639 2022-08-09 10:12:38 875 Views1 Replies
to Whom it May concern
I got O3 sensor: Gravity: I2C Ozone Sensor (0-10ppm)  from dfrobot
while I am integrating this sensor with raspberry pi and run the code available at your GitHub
the sensor showed "error 121"
I checked the I2c on raspberry pi and it connected
any solutions or guides for this problem
2023-03-02 19:57:01
Please notice that Gravity: Electrochemical Ozone Sensor (0-10 ppm, I2C)(SKU:SEN0321) only support Raspberry Pi3, we didn't test it on other board yet.
Also, could you check the swithes on the sensor? Make sure that you enter the right I2c Address.
userHeadPic NeloKin
