Forum >Does Gravity pH sensor work with Arduino nano?
TroubleshootingArduino
userHead tavolivos 2022-08-09 17:14:36 430 Views1 Replies
Just that question. If so, is there any tutorial for this? I have only found tutorial with arduino uno.
2022-08-09 19:36:46
Hi, The Nano is used in the same way as UNO, which is to connect the PH sensor to the analog foot and then upload the sample code to read the analog amount and output the PH value
userHeadPic Winster
