Forum >FireBeetle Board-ESP32 FAQ【DFR0478】
userHead jenna 2022-08-11 22:26:54 3840 Views0 Replies
1.code doesn't work
FireBeetle made a pin mapping for Arduino IDE. It can be configured with Dx transport.
SoftwareSerial mySoftwareSerial(D10,D11);//TX,RX
2.The built-in hall sensor cannot be used
The internal hall sensor is not functioning properly. It is recommended to connect the sensor externally.
3. FireBeetle ESP32 not in COM devices
Please install the driver CH340 and change the data cable.
4.serial.serialutil.SerialException: Cannot configure port, something went wrong. Original message: WindowsError(5, 'Access is denied.')
Please try another computer.
5. Approximate Bluetooth transmission distance (open environment)
about 20m
6.The USB port disappears when connecting to an Ubuntu computer.
For the CH341 uart converter, the Braille terminal automatically took control of the device and crashed it (which made the ttyUSB0 disappear), You can find the solution by following the link below:
https://stackoverflow.com/questions/70123431/why-would-ch341-uart-is-disconnected-from-ttyusb
(Thanks to Mr Nicolas for this faq
