IoT Router Carrier Board Mini FAQ【DFR0767】
Q1:Using USB-C to connect to PC to burn image, the device cannot be recognized.
A1:Please check if the USB cable supports data transfer, some of the power-only USB cables are not connected to the data pins
The hardware is not currently compatible with native USB-C to USB-C connections, please use a USB-A to USB-C cable to connect to your computer
Q2:Raspberry Pi OS install r8168-dkms report ERROR.
A2:Some versions of the Raspberry Pi OS kernel do not support the installation of r8168-dkms. We recommend using Ubuntu Server, which has been tested to install.
Download Ubuntu Server For Raspberry Pi at (https://ubuntu.com/download/raspberry-pi)
Q3:The ETH does not work after you download the provided Openwrt system.
A3:The new version of CM4 runs a new firmware that is not included in any of the widely available OpenWRT releases.
Swapping out the .dat and .elf firmware files on the FAT32 boot partition, w/ the latest firmware files from RPi GitHub (https://github.com/raspberrypi/rpi-firmware) made it work.
Thanks to Mr. M for discovering the problem and providing us with a solution.
Detailed tutorial of building a custom OpenWRT image for Raspbnerry Pi Routerfrom Vinicius Paes:
Portuguese tutorial:
https://viniciuspaes.com/raspberry-pi/tutorial-roteador-raspberry-pi-openwrt/
English tutorial:
https://viniciuspaes.com/raspberry-pi/how-to-build-custom-openwrt-image-raspberry-pi-router/
Thanks to Vinicius Paes for his work!
