Forum >Compute Model 4 IoT Router Broad Mini -
userHead Bit2021 2022-08-20 21:30:38 1690 Views1 Replies
the OpenWRT 21.02.3 DFRobot Release image listed on the wiki seems to be the normal WRT release. I'm not able to get eth1 working. Just Eth0.
Can you double check if the file is correct?
2022-09-23 18:33:55
Compute Model 4 IoT Router Broad FAQ:https://www.dfrobot.com/forum/topic/315198
userHeadPic jenna
