Forum >SEN0257 GRAVITY WATER PRESSURE SENSOR
userHead CultivoAeroponico 2022-08-24 07:48:58 573 Views1 Replies
i'm worry about if the gravity water pressure sensor it works in raspberry pi or it just works on Arduino
2023-03-02 01:40:21
Gravity: Analog Water Pressure Sensor(SKU:0257) is an analogue output device, which means that it does not need a library and can work with any MCU with ADC.
So, it will work with rasoberry pi.
userHeadPic NeloKin
