Forum >No CO values returned on the SEN0466 CO sensor
userHead Avhoboken 2022-08-26 10:36:40 987 Views2 Replies
I have issues getting the CO values out of the SEN0466 sensor. I have created the exact test set-up (hardware, wiring and script) as described in the Wiki, using a DFRobot UNO R3 and the SEN0466 CO Sensor. It does return the temperature but CO value (AllDataAnalysis.gasconcentration) keeps showing 0.
It's now running for three hours but no change so I assume something is wrong.
Any suggestions?
ps. I also find the returned temperature about 2C higher than measured by other (DFRobot) sensors like the DHT20 and DHT22, even with Temp. compensation enabled (gas.setTempCompensation(gas.ON))
2023-06-08 05:40:59
I'm also seeing this symptom (0ppm + temperature too high by 5C) with my SEN0466.
Could you please describe your fix?
userHeadPic Bruce.McKenney
2022-08-28 02:12:33
solved, was misreading the values
userHeadPic Avhoboken
