Forum >Obj Learn and Obj Name uses different length ID numbers
General HUSKYLENS
userHead tguneysu 2022-08-27 23:06:04 1570 Views0 Replies
In the following two commands, the object ID field is two different lengths:
Learn: uses a 2-byte ID number.
Name: uses a 1-byte ID number.
If one LEARNS an object with a 2-byte value (which is possible, and executes OK), then it is NOT possible to assign a name to that object with the obj ID created earlier. One gets an error.
Please SYNCH the two ID fields so that same byte-count ID numbers are possible.
- Learn the current recognized object on screen with a chosen ID
Data details:
Data      Function
0x01      Given ID, see ID Details above (Low Byte of 1 = 0x0001)
0x00      Given ID, see ID Details above (High Byte of 1 = 0x0001)
- Set a custom name for a learned object.
Data details:       Name: TEST
Data      Function
0x01      Given ID of object
