Forum >Ulstrasonicsensor SKU_SEN0307 reads wrong values
TroubleshootingGravity
userHead awakencaptive 2022-09-02 11:11:46 818 Views1 Replies
I have got the following sensor: https://wiki.dfrobot.com/URM09_Ultrasonic_Sensor_(Gravity_Analog)_SKU_SEN0307
So its an older version of URM09.
I copied the code from the link and tried it on my arduino uno. It measure the following distances:
142,cm 143cm, 144cm
These distances are wrong, because I put the sensor at a distance of about 4 cm…
Does any of you have any idea what could be the error here?
2022-09-02 11:19:51
Got it! Sorry, I put attached it to the wrong pin… not an analog one ;)
userHeadPic awakencaptive
