Forum >SEN0524 arduino script problem
TroubleshootingArduino
userHead NikosMavrikis 2022-09-08 06:25:00 672 Views1 Replies
I have been trying to use https://wiki.dfrobot.com/SKU_SEN0524_ToF_Outdoor_Laser_Ranging_Module_15m with the arduino debug code in the link and it does not seem to serial print anything. I have used the sensor with a FT232 USB to serial and it works fine. Had anyone else had a similar problem with the script given?
Best regards
2022-09-20 00:55:27
Hi, Check whether the baud rate of the serial port monitor is consistent with the code.Please change the connection of TXRX to check whether there is data output.
userHeadPic Winster
