Forum >Infrared CO2 Sensor FAQ【SEN0219】
userHead Winster 2022-09-09 17:33:23 5602 Views0 Replies
Q1:My sensor readings are fluctuating, why is this happening and how can I fix it?
A1:Due to the high sensitivity of the sensor, it is normal for the readings to vibrate. If you need to get a smoother output curve, you can take the average of the data in a range.
Q2:Why can't my sensor output normally?
A2:
1.The sensor needs to be preheated about 3 mins before use. And please calibrate the sensor for the first time. For details, please refer to Wiki: (https://wiki.dfrobot.com/Gravity__Infrared_CO2_Sensor_For_Arduino_SKU__SEN0219#target_4)
2. This carbon dioxide sensor has undergone product replacement, and the communication method has changed from analog(V1) to PWM(V2). Please check your sensor version. If it is V2 version, please refer to our Wiki example, if it is V1 version, please refer to the following code:
 int sensorIn = A0;
void setup(){
  Serial.begin(9600);
  // Set the default voltage of the reference voltage
  analogReference(DEFAULT);
void loop(){
  //Read voltage
  int sensorValue = analogRead(sensorIn);
  // The analog signal is converted to a voltage
  float voltage = sensorValue*(5000/1024.0);
  if(voltage == 0)
    Serial.println("Fault");
  else if(voltage < 400)
    Serial.println("preheating");
  else
    int voltage_diference=voltage-400;
    float concentration=voltage_diference*50.0/16.0;
    // Print Voltage
    Serial.print("voltage:");
    Serial.print(voltage);
    Serial.println("mv");
    //Print CO2 concentration
    Serial.print(concentration);
    Serial.println("ppm");
  delay(100);
(If you need to use V1 sensor with 3.3V motherboard, please adjust the code to float voltage = sensorValue*(3300/1024.0);)
Q3:What's the output frequency of the sensor?
A3:See the pic below:
