Forum >sim7000 NB-IoT Expansion Shield FAQ【DFR0572/DFR0505】
userHead jenna 2022-09-23 01:03:53 3059 Views0 Replies
Q1:The serial monitor shows that the card is on turn on SIM7000...
A1:1. Check whether an external power supply is connected. Input Voltage: 7-12VDC (VIN range: 6-20V). The micro USB port of the Sim7000 expansion board cannot be used for power supply, but for burning firmware.
2. Try to replace the external power adapter/lithium battery.
3. Try to manually turn on the SIM7000, press and hold the Boot button for 2 seconds.
Q2: Fails to attach the service
A2:1. Please check the signal strength, use AT command to check the signal strength, if there is no signal or the signal is too poor, change the place/change the antenna.
2. Try to change the network standard (according to the sim card type), setNetMode NB to GPRS.
3. Try attaching the service manually, using AT commands.
Q3:Is it available in a certain region?
A3:It needs to be determined according to the frequency band provided by the local operator.
