Forum >PLEASE HELP - STH1X SENSOR SENDING RANDOM VALUES
userHead ASHGI 2022-09-23 16:53:40 2227 Views2 Replies
I'm trying to connect my new STH10 Temperature sensor from DFRobot with NodeMCU (using Arduino IDE). I tried it with the program and connection from this article (http://www.esp8266learning.com/wemos-sht11-example.php)
(along with a 10K resistor across VDD (3.3v) and DATA pin as mentioned in DFRobot wiki page)
But it is sending me an error output like this:
Temperature: 615.3499755859C / 1139.6300048828F. Humidity: -6143.06%
And the values are not changing at all. (Also with/without resistor its the same output)
Does anyone know how to resolve this?
Please help me
Many thanks
Ash
2023-03-25 02:53:17
Hello everyone:
I have a problem with the same sensor and the same circuit, although connected to Arduino.
The sensor readings are similar (erroneous):
Temp: -40, Hum: -6%
This happens to me with two units of the same sensor, so I think I'm doing something wrong in the connection.
On the sensor's packaging it says: SEN0148 - SHT10.
Did you manage to get it to work?
Best regards and thank you very much.
userHeadPic Javier.Camara
2022-09-23 18:04:50
Did you buy this sensor?
Digital Temperature & Humidity Sensor (With Stainless Steel Probe) : https://www.dfrobot.com/product-912.html
userHeadPic jenna
