Forum >How to select alternate I2C address in code?
ArduinoTroubleshooting
userHead CasAng 2022-09-30 04:47:08 2100 Views2 Replies
I have 2 SEN0373 boards that I need to connect to the same Arduino, and read from both.
I can connect one without problem, and individually they both work fine.
Now I have shorted the address selector on one of them, to change the I2C address from 0x68 to 0x69, and connected them both to the same I2C bus.
I cannot figure out how to select the secondary sensor on address 0x69? I assume that I need to create two bmx objects, with something like:
#include <DFRobot_BMX160.h>
DFRobot_BMX160 bmx160_a; // first device in default address
DFRobot_BMX160(&Wire, 105) bmx160_b;  // Second device on alternate address 0x69h = 105d
But I get a lot of errors about wrong data types…
Can you please show me how I set the correct address?
BR Casper.
2022-10-19 18:53:58
userHeadPic jenna
2022-10-19 18:51:50
Hi!
Sorry, the library of this sensor uses 0x68 by default. It is recommended that you refer to the library file of another product and modify the library file of SEN0373.Product wiki: https://wiki.dfrobot.com/Gravity_I2C_LIS2DW12_Triple_Axis_Accelerometer_SKU_SEN0409Library: https://wiki.dfrobot.com/Gravity_I2C_LIS2DW12_Triple_Axis_Accelerometer_SKU_SEN0409
userHeadPic jenna
