Forum >Lattepanda delta 3 auto power on doesn't work sometimes
userHead kandipr 2022-10-07 12:59:05 5384 Views8 Replies
We have about 100 Lattepanda deltas that we are using in our project. They are enclosed in a machine so we configured the auto power-on feature as per the instructions provided on this GitHub page - https://github.com/LattePandaTeam/LattePanda-Win10-Software/tree/master/BIOS%20for%20LattePanda%20Alpha%26Delta/LattePanda%20Delta/S70GR200%20Delta%20Default%20BIOS
While the auto power-on feature works most of the time, in some cases Lattapanda doesn't start. We have to open the machine and manually press the power button to start it. This is becoming a massive pain and we are now regretting our choice. Lattapanda is powered using the original USB-C power adapter shipped with it.
Does this have anything to do with the RTC battery? If so, how often we should change these? In our project, Lattapandas are running 24/7.
Thank you for any help in advance.
2025-07-25 22:36:56
Hello There,
unfortunately i experience the same Issue.
Best regards,
Stefan
userHeadPic StefanXP
2025-02-12 04:19:56
We have the same problem. In fact, our board is powered by an external battery. If we disconnect the battery immediately, the plug it again, it powers on correctly, but if we keep the battery until it gets empty, the board shuts down, but doesn't goes up when we replace the battery with another charged one, we need to click the power button (bios has been setup correctly and the AUTO and SW pins are shorted on the board.
userHeadPic Ahmed.Lazreg
2024-11-02 01:16:59
Hi, we are having the same power up issue, where the Delta 3 units will not power up, even with the BIOS setup setup correctly.
Our units use the 12V input. Maybe there a firmware update to correct this?
I tried with a capacitor on the SW signal to simulate the momentary assertion of the SW signal at power up, but it does not work everytime… If you can provide the schematics of the board, I'll be happy to find something that works.
Thanks!
userHeadPic Francois.Champoux
2024-10-28 19:16:10
I hope you keep writing stories like this one and others that are fun to read slope run
userHeadPic Will.Arnett
2024-10-28 19:14:13
If the machines are in a controlled environment, consider any factors like temperature or humidity that might affect performance. Check https://slope-run.io
2024-10-23 14:26:02
Hi, we have the smae issue, can you help and provide the exact steps to follow to fix this please?
userHeadPic sean.farmar
sean.farmar wrote:
I'm attaching a screenshot of the Apyio setup screen:
2024-10-28 17:13:37
2022-10-07 21:14:14
1. Copy the right EC files directly to root of the USB drive;2. Plug your USB drive in Delta USB host, boot up the system;3. Press “ESC” and go into the BIOS manu;4. Navigate to Save & Exit. Choose “UEFI: Built-in EFI Shell” in Boot Override and press “Enter”5. Now type dir and press enter. This will list all content on the USB Drive;6. Type in eFuitX64 /u S70GR100-0220-A.bin /faildelay and press enter.(You can also use “Tab” key to fast choose the right file) .
Now restarts, it will work normally
userHeadPic JamesWalter
