Forum >How do I interface Huskylens with Nodemcu?
userHead SiddhantIndave 2022-10-11 20:31:26 1992 Views3 Replies
I tries several times and connected the Huskylens TX and RX to Nodemcu D1, D2 (SCA,SCL) but it does not work. Does anyone know how to interface these two?
2023-04-17 10:29:45
Wouldn't it be possible to use a level shifter for the I2C Connection?
userHeadPic Birgit.Straker
2023-02-23 15:29:27
HuskyLens consumes heavy current, up to 3.3V 320mA or more.  Therefore, external power supply is required. You can connect the external power supply or the HuskyLens USB connector. But Huskylens do support 3.3V.
userHeadPic R2D2C3PO
2023-02-23 00:59:45
Please notice that Gravity: Huskylens - An Easy-to-use AI Camera(SKU:SEN0305) requires 5V I2C voltage. Nodemcu is 3.3v I2C. I'm sorry that it can not work with Nodemcu.
Hope it can help.
userHeadPic NeloKin
